Roues origine 280zx
  • Roues origine 280zx
    http://xenonzcar.com/s130/wheeldifferences.html
    The 1979-1983 S130 came with five different wheel combinations from the factory. All the wheels have the 4 X 114.3mm bolt pattern. The chart below has the information regarding these wheels.
    Wheel Offered On Offset/Backspace Weight Stock Tire Size Part Number
    Stock Steel
    1979-1983 +15mm/Unknown Unknown 195/70R-14 40300-P6500
    Iron Cross
    1979-1980 +10mm / 102mm 18 Lbs 195/70R-14 40300-P7127
    Six Spoke
    1981-1983 Non-turbo + 12mm /101mm 13 Lbs 195/70R14 4030-P8186
    Snowflake
    1981 Turbo +12mm / 101mm 17 Lbs 205/60R15 40300-P9000
    Swastica
    1982-1983 Turbo +12mm / 101mm 14 Lbs 205/60R15 40300-P9525
    Wheel Covers
    On S130's that came with the Steel wheels only, Plastic wheel covers were added. They are pictured below.
    The 280zr was one of the cars offered with these wheels.
