Vide Garage pieces 240Z de 06/1973 origine US
  • Vide Garage pieces 240Z de 06/1973 origine US
    Bonjour a tous,
    Besoin de place dans mon garage, voici la liste de toutes mes pieces, hors frais de port ou à venir chercher sur Toulouse.
    Annonce à suivre sur le boncoin
    Category Qty Description Status Unit Price EUR
    Interior Part 1 Shift Knob, Manual Transmission used 70
    Interior Part 2 Window Crank, Black + Crank protector new 25
    Interior Part 1 Window Crank, Black used 20
    Interior Part 1 Armrest, Left new 25
    Interior Part 1 Armrest, Right new 25
    Interior Part 2 Door handle chrome finisher restored 20
    Interior Part 2 Door handle chrome finisher used 13
    Interior Part 2 Interior Door Handle + Trims used 28
    Interior Part 2 Doors blockers used 5
    Interior Part 1 Window system LH & RH restored 60
    Interior Part 2 Seat Belt used 25
    Interior Part 2 Fuse Box covers console used 35
    Interior Part 1 Dash center vent new 40
    Interior Part 1 Cigar used 5
    Emblem 1 Roof Emblem used 20
    Instrument 2 Speedometer used 80
    Instrument 2 Tachometer used 125
    Instrument 2 Amp / Fuel gauge used 90
    Instrument 1 Oil Pressure / Water Temperature gauge used 90
    Interior Part 2 Interior hatch restored 20
    Suspension 4 Stock springs restored 20
    Bumpers 2 Front Bumper brackets LH & RH restored 70
    Bumpers 1 Rear Bumpers additional guards used 80
    Bumpers 2 Rear Bumpers guards Left & Right used 35
    Bumpers 2 Front Bumpers guards Left & Right used 70
    Electrical 1 Washer Tank & motor used 90
    Cooling System 1 Radiator overflow tank used 10
    Locker 1 Hood locker used 10
    Locker 1 Glove box lock used 10
    Engine Bay 1 Horn used 15
    Engine Bay 1 Engine inspection light used 10
    Fuel system 1 Mechanical Fuel pump & tube used 25
    Fuel System 1 Choke Cable used 80
    Fuel system 1 Pair of S.U. Carburettor used 300
    Fuel system 1 Stock Manifold used 50
    Fuel system 1 Fuel Tank restored 250
    Header & Exhaust 1 Stock Header used 80
    Header & Exhaust 1 Performance 3+2 Header + exhaust line new 200
    Lighting 2 Turn signal Assembly used 50
    Lighting 4 Marker Light used 25
    Lighting 1 Tail Light set used 200
    Lighting 1 Headlight set & trims used 100
    Exterior 2 Mirrors used 30
    Suspension 1 Stock front sway bar used 40
    Exterior 2 Stock front towing hook restored 5
    Exterior 1 Stock rear towing hook restored 10
    Exterior 2 Doors restored 120
    Exterior 1 Hood restored 250
    Brake 1 Stock Front brake set incl. Disc used 200
    Brake 1 Stock rear brake set incl. Drums used 200
    Clutch 1 Stock flywheel + standard clutch used 100
    Cooling System 1 Radiator used 100
    Instrument 1 Speedometer cable used 40
    Dernière modification par JeanMex, 29 mars 2017, 12h09.
    Datsun 240Z - 1973
    Caterham 1600 SS - 2000
    Interested Jean mais l'assembly est lequel stp ?
      Ce type la, seul sont montrés sur la photo les covers mais je vends les block complets
      Datsun 240Z - 1973
        Si dispo, je suis preneur des Turns light assembly pour ma 240Z.
        Benoit
          Ok, c'est ça que je cherche - covers et blocks complètes. Me dire combien en tout avec les console fuse covers et fdps et je vais régler ça par paypal, chèque : comme tu veux.
            OK Je te dis ça ce week end. As tu un Mondial Relay près de chez toi (le plus économique max 10€ pour cet envoi je pense). By the way, oubliè dans ma liste, j'ai une console central presque neuve de chez MSA. Interressé?
            Datsun 240Z - 1973
              Salut Jean, je suis intéressé par l'horloge, l'éclairage d'inspection moteur et un couvercle de console centrale de boite à fusible
              Merci !
                Merci !
                Horloge: vendue
                Couvercles de console : vendus
                Eclairage inspection: ok pour toi
                Datsun 240Z - 1973
                  Oui, PM moi le prix globale stp.
                  BOUT'CHOU BOUT'CHUTES
                  21 PLACE DE L'EGLISE
                  85700 - POUZAUGES
                    Zut pas assez rapide !
                    OK pour la loupiote Jean : elle est complète ?
                      Comme sur la photo
                      Datsun 240Z - 1973
                        Nickel, je peux te régler via Paypal ?
                        Envoie-moi ton adresse stp.
                          Hello,
                          interessé par:
                          Possible d'avoir une photo, j'ai peur de me tromper !
                            Envoyé par Monsieur Bou Voir le message
                            Hello,
                            interessé par:
                            C'est ceux la
                            Datsun 240Z - 1973
                              Merci beaucoup JeanMex.
                              J'ai bien fait de demander, c'est pas ceux là, je cherche les embouts chromés en plastique de la poignée de porte coté passager.
